anyone with an X9 and harmony 1000
tabs
Established Member
im considering the harmony 1000 remote, but can the harmony work all the settings in the X9 menu's ? cheers
i use the 885. but I only use it to automatically power it on and off, after that it auto selects the input. i use the remote if i ever need to adjust the settings.
Uzeless
Established Member
Aren't Harmony's fully programmable? You should be able to 'learn' all the functions if you have the original remote.
tabs
Established Member
i see what your saying, but does'nt that difuse the idea of having a multi remote :rotfl:
tabs
Established Member
so ive heard, but i need it to switch between ... movie, game, user settings etc
plus the added comfort of another remote if the supplied X9 one goes toots up, as there are no other manual buttons on the X9 to use :smashin:
kamban
Hi.
I have a question about X9, that you may be able to answer.
When connecting my NAD T515 DVD to X9, using HDMI, it says unsupported signal, automaticly finding the signal.....
Do you have an idea what i can do to help this problem?
Kamban
kamban
And it's not the lenght of the cable. As suggested by a guy in a store here in Copenhagen.
I have tried both a 1 and a 10 meter cable. Samme answer.....
tabs
Established Member
Hi.
Kamban
is the DVD player a blu ray jobby ? ... if so it could be that the DVD player is set to 1080p ... just a thought like
Is 8K TV dead? Philips OLED+907, Pioneer LX505 AVR plus B&W 700 S3 Reviews & Visit + AV/HiFi News
