Anyone with a Raspberry Pi & a (sony) AV amp?
Discussion in 'Video Streaming Boxes & Services' started by Schlaag, Feb 24, 2014.
  1. Schlaag
    Schlaag
    Feb 16, 2014
    72
    +11
    Hi all
    I've had a problem with a Pi & AV amp combo..
    My Pi has XBMC loaded and is connected via HDMI to my AV amp (Sony 840 and now a 1040)
    When the Pi is attached to the amp via HDMI the amp fails to switch on. The green power light is lit but nothing actually switches on in the Amp, its 'dead' and unresponsive.
    As soon as I remove the Pi from the HDMI cable the Amp works as normal!
    I have tried different cables and hdmi ports on the amp, the same happens
    Is something within the Pi shutting my amp down!?
    thanks
  2. next010
    next010
    May 29, 2005
    10,838
    163
    +2,127
    Is HDMI-CEC (bravia sync I think they call it) enabled on the amp ?
    If so try turning that off and see what happens. I have an older Sony amp and it's called HDMI-CTRL on it.
  3. metalguru
    metalguru
    Apr 4, 2005
    1,214
    Scotland
    +136
    My Pi running Raspbmc works fine with my Sony AV820
