Anyone willing to share his/her experience...
ddlooping
Some info about the Denon AVR-770SD:
• 6-channel digital power amp with total output of 600 watts
- Dolby Virtual Speaker, for dramatic surround in 2 or 2.1 channels • Dolby Headphone for private surround
• 32-bit floating point Hammerhead SHARC DSP, as used in DENON's £3000.00 high-end AV amps.
• Auto Decode function detects the format of the incoming signal from the disc being played and selects the most appropriate surround decoder. Multi-channel sources in DTS and Dolby are played back in surround. 2-channel sources can be played in stereo or in multi-channel via Dolby Pro Logic II / DTS Neo:6
• Video Conversion converts composite to S-Video
• Comprehensive inputs & outputs inc component video
• 6ch external input supports SACD & DVD-Audio multi channel sources
• Banana plug speaker terminals for all channels • 435 (W) x 80 (H) x 380 (D) mm
http://www.denon.co.uk/PDF/SDSeries.pdf
ddlooping
Thanks for the reply, hornydragon. ;)
The Sunfire has preamp outputs for all channels.
This would seem to indicate it's not a true digital pre/amp (as I understand it), as there would have to be a digital to analog conversion somewhere.
Maybe the conversion is only present to feed these outputs, and the path between the pre and amp actually stays in the digital domain.
hornydragon
I didnt go to see the sunfire range it just happened to be driving the soeakers i was auditioning. The lack of DVi or HDMI makes me think that you are probably right but are you talking of Digital processing, Digital amplification or Digtal signal paths?
avanzato
I've been following some of the threads on the digital amps. That they supposedly sound this go so early in their life is a good sign but it doesn't look like they're always a magic way to great sound. The Panny needs some tweaking to give it's best apparently and the Harman DPR 1001 gets panned more than it gets praised.
I was thinking of trying the BK electronics modules or even building a Zap pulse stereo amp. Haven't got the spare cash to waste on experiments at the moment unfortunately. :(
That Denon looks very interesting and only £350 I wonder how it handles low impedence loads?
