Anyone using the spdif input on an xfi card?
CaPo
Ive just wired my xbox 360 up to my xfi soundcard via the creative digital i/o module. It works fine if I have the xbox set to digital stereo but I get no sound if I set it to dolby digital. Any ideas? Im just about to try it with a dvd player to see if its just the xbox's signal it wont recognise.
should work, used to with older sound blaster cards, make sure you have the soundcard set to use inbuilt decoders on the card... in the control panel/audio HQ..., also check creative forums...
