Jon Weaver
I have an 55EC930V and have only ever used a Harmony One remote.. I just upgraded to SkyQ and currently am forced to use their remote until I find another solution and immediately found an annoyance
At the top right of the Sky remote, there is an input select button, which brings up the inputs on the TV.. The problem is, LG need you to press BACK to select or clear this menu, otherwise it just sits there.
I have found that if you change input and wait about 5 seconds, it will change to the new input.. And then if you repeat it, you can go back to the original input (after waiting 5 seconds again), but this is beyond annoying.
Has anyone else noticed this and if so, come up with a workaround? Is there any way to disable this button? And if not, allow the BACK or ENTER key on the TV to be sent?
Jon
Jon
