Anyone using S-Video on Sky+ ?
Discussion in 'Sky Digital TV Forum' started by galewis1, Oct 4, 2004.
  1. galewis1
    galewis1
    Apr 11, 2004
    354
    Peterborough
    +4
    Hi..
    I'm using my receiver to control all AV switching and therefore need to use the S-Video output from my Sky+ box. (I have thought about RGB to Component conversion, but not keen on the expense of it right now).
    Within Sky+ setup, you can set up output to RGB or PAL (PAL = composite, right?). What about S-Video then? It that option hidden away elsewhere in the menu system?
    Gary
  2. Jules
    Jules
    Oct 11, 2000
    5,581
    134
    +1,039
    Sky+ boxes have a dedicated S-Video (4 pin) socket which works regardless of the picture set up menu settings.
    I connect my Sky+ box to my AV amplifiier (along with everything else) and then connect the amp to the TV.
    It works very well, really simplifies things and the picture quality is great.
  3. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    I've got a standard digi-box connected to my amp via a JS Tech RGB>YUV converter and a Sky+ box connected via S-Video... If anything the S-Video gives a better picture...
  4. AFC
    AFC
    Sep 9, 2004
    76
    Yeah, I use S-Video to connect my Sky+ box to my plasma and playing about with the Sky+ settings didn't appear to have any effect.
    I'm actually very pleased with the S-Video connection although fast panning ie football and text scrolling across the screen can look a little blurred at times but I'm not sure what the cause of this is.
  5. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I'm using the s-video to feed my PC and then via Dscaler onto a 19" LCD monitor, can't compare the signal to a RGB feed but it's look pretty darn good all things considered.
    Mind you the video processing Dscaler can do is probably a huge benefit.
