Anyone using prog pal on Arcam DV27
Discussion in 'Blu-ray & DVD Players & Recorders' started by sticker, Aug 31, 2003.
Tags:
  1. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Anyone using prog pal from the top component outputs on the Arcam DV27?
    The reason I ask is that I may have a problem with mine as I am getting 2 pictures in a split screen
    John:confused:
  2. jont
    jont
    Apr 8, 2002
    4,243
    near Aylesbury
    +545
    No probs with mine into my av8 and out to my panny ... has it worked before ?
  3. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Thanks for the input Jont
    This is the first time I've used it as I didn't have a prog scan compatable monitor before. Works fine out of the second set of components and SCART. Suppose it might me a setting on the plasma but I can't seem to find.
    Regards
    John
  4. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    I know with my sim2 if the projector is expecting interlaced and it is given progressive then the screen is split in 2.
    good luck :)
    CaM
  5. yatesd2404
    yatesd2404
    I run PAL Prog from my DV27 to a Sharp projector and have never had any problems. The Sharp does automotic recognition of the signal so have never had any issues.
    Good luck,
    Dave.
  6. jont
    jont
    Apr 8, 2002
    4,243
    near Aylesbury
    +545
    I used to get this on my old 'orion' plasma as it wasn't progressive-capable (which is one of the reasons it went back !!) ... I would have thought that the pioneer was ... maybe something needs to be enabled in the menu ?? do you need to tell it how to expect a sync signal ? or is it expecting rgb and you are sending YprPb ??
  7. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    The pio is def pal prog capable.
    Don't think I need to tell the Pio about a synch signal but hopefully my dealer can sort it out for me..pleeeeease.
