Anyone using DVI with Philips 32PF9986 ?
Discussion in 'Philips TVs Forum' started by idhutt, Jun 9, 2004.
  1. idhutt
    idhutt
    Is anyone using the DVI input on the Philips 32PF9986 ?
    If so, a few questions:
    1. Is it HDCP compliant
    2. Can it therefor take HDMI input (via a HDMI/DVD converter)
    3. Can it display DVI at native panel resolution?
    4. What is you impression with the quality of this set when used with DVI input.
    Ian
