shotokan101
Hi - looking for some info./suggestions/feedback on using wireless transceivers for connecting a sub ?
Jim
Jim
Indeed. Most, if not all(?), receivers nowadays have automatic calibration that will set this delay for you.
You will need to delay all the other speakers to match your sub. Not normally a problem though.
I assume the wired link option doesn't work?
No delay? It says 14ms latency in the description?
