Anyone used the VGA output on a skyworth 1050D to connect to their Z1?
Discussion in 'Projectors, Screens & Video Processors' started by hopdylan, Mar 11, 2003.
  1. hopdylan
    hopdylan
    Jan 5, 2003
    172
    I tried the VGA output on my Skyworth the other night with a 5m VGA computer cable and have found that it gives a sharp picture but with a few vertical lines on the image - does anyone know if this is a problem with the output or whether i need to fiddle with some settings on my Z1?
    Thanks in advance
  2. olaiho
    olaiho
    Yes, this combination has been tested by a few users in Finland.
    The vertical lines are there probably because you haven't calibrated VGA in the Z1.
    The way you do this is you press "PC AUTO ADJ." button on the remote.
    After this, the picture should be problem free. If you are still not satisfied with the picture, try manually adjusting some settings on the Z1, eg. Total Dots, Horizontal and Vertical.
    Here are a few ready Z1 settings you can try with the Skyworth:
    PAL dicsc
    Fine sync: 15, Total dots: 850, Horizontal: 152, Vertical: 42, Display area H: 700, Display area V: 556
    NTSC discs
    Fine sync: 10, Total dots: 732, Horizontal: 125, Vertical: 35, Display area H: 600, Display area V: 480
    If you are not satisfied with these, perform AUTO ADJ. and after that just adjust settings manually to your liking.
    The VGA calibration should be performed separately for NTSC and PAL, because they are treated as different resolutions.
    BR,
    Olaiho
    p.s. Check that Skyworth video output is set up as "AUTO", not PAL or NTSC.
  3. olaiho
    olaiho
    Not even a "Thank You"?
    Why do I even bother writing...
  4. hopdylan
    hopdylan
    Jan 5, 2003
    172
    Sorry olaiho , been a bit busy lately so haven't got round to trying out the settings you provided
    Thanks in advance though! :clap: :clap: :clap:
