Anyone used Telewest with Toshiba RDXS34?
Discussion in 'Cable TV & Virgin Media TV' started by mobily, Nov 7, 2005.
  1. mobily
    mobily
    Dec 30, 2003
    505
    Plymouth
    +3
    Hey all,
    Has anyone here successfully used Telewest with the above mentioned dve recorder.
    For example if I wanted to record something on BBC 3 at 8:00 and then BBC 4 at 9:00 would a programmed Toshiba change the channel on the Telewest box?
    Thanks :thumbsup:
  2. fieldl
    fieldl
    Jun 29, 2005
    30
    I'm on NTL and can set a reminder for a program. This will automatically change the channel to the correct one when required.
    That's how I do it. I guess Telewest would be similar.
