Anyone used iscan ultra DVI output with their pj?
Discussion in 'Projectors, Screens & Video Processors' started by Messiah, May 12, 2003.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Has anyone used or seen this combination. If so, is there much improvement over a standard component connection or does the initial A > D conversion defeat the object somewhat.
    With the recent price reduction on this unit I'm wondering whether it may be a good solution for connecting all sources and feeding inot the DVI input.
    Thoughts?
  2. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    ive been reading the online manual for the ultra.
    and one point to note is the
    DVI output will only work with ntsc i/ps.
    http://www.dvdo.com/pro/pro_isu.html
    take a read here, i found it best to right click and save the file.
    didnt seem to auto read.
