Anyone used Endeva?
Discussion in 'Plasma TVs Forum' started by Lino, Jul 5, 2003.
  1. Lino
    Lino
    Sep 21, 2002
    191
    Wembley
    +15
    For delivery and installation of their plasma screen? I ask because I want to know if it's worth the £99 the supplier is charging and if they are willing to move other TV sets around the house while they're here (I've got a 25" Sony CRT that I really can't lug DOWN the stairs myself etc)..
    Thanks! :)
    Lino
  2. poggs
    poggs
    Endeva will leave the tv at your front door. The rest is up to you. Unless you have made a separate aggreement somewhere. Such as Currys do with their £25 and we'll set it up for you charge.
  3. Lino
    Lino
    Sep 21, 2002
    191
    Wembley
    +15
    Quoting from the flattelly.com website..
    The Installation Service includes:
    Unpack all items in one suitable location.
    Install the screen onto the supplied stand.
    Using cables supplied by the manufacturer, connect to existing terrestrial, Sky or cable TV services.
    Connect all supplied equipment together.
    Connect speakers and tack speaker cables along skirting boards.
    Demonstrate the basic controls of your new system. (Manufacturer's operation manuals will be supplied for more advanced details.)
    Please have sufficient mains sockets available at your preferred location. You will probably need at least 4 plug sockets. Connection will be limited to manufacturer's cables and extension AV cables will not be supplied.
  4. blindlemon
    blindlemon
    Endeva have now gone bust.
    See here
    :clap: :clap: :clap:
