Anyone used dvdplanet.com?
Discussion in 'Movie Forum' started by cyberdudelion, Jan 2, 2001.
  1. cyberdudelion
    cyberdudelion
    Hi Folks
    Looking to make my my first purchase of the year from www.dvdplanet.com (fomerly kencranes.com). Has anyone ever used them or heard anything negative? They seemed to be rated well by bizrate.com. Shipping will be within the USA.
  2. h0l1yw0od
    h0l1yw0od
    Nov 16, 2000
    477
    +13
    I used them to get Bugs Life CE. It took some messing around to get sorted as they check your details with the bank before shipping your order. I had to fax a copy of my credit card statement to them but after that i recieved my disk in less then a week! The only thing was that they didn't send confirmation that they had posted it and i emailed them twice with no reply (due to the holidays?)
    But if your willing to fax/post if they ask for it then i recomend them. But i've only used them once.
    "Can we blow up the Earth?"
  3. Napoleon
    Napoleon
    Jan 1, 2001
    I ordered from Ezydvd.com.au.They emailed me asking for a copy of a credit card statement,and a picture of my credit card!.
    I didn't like the idea,so cancelled the order.
