Question Anyone used AVSHD,Contrast setting.
_Dragon_
The brightness was easy,But im struggling to adjust my contrast right as its saying adjust your contrast so 230-234 or above flashes,Well all of the numbers flash even if its at 0 or 100% contrast.
scottthehat
thats good then. just make sure you dont get a colour shift high up the white level as it can shift the greyscale.
_Dragon_
I must be reading the setup wrong because having the contrast up high cant be good. Im thinking im not reading it right because of this thread:
scottthehat
it just means make sure you have them 4 bars flashing as that's reference white, anything above is extra and a bonus, alot of content wont have this anyway.
scottthehat
Because that guy when he ups his contrast it gets ride of bars above 234 then hes not hurting anything just using any extra headroom he may have, but its not needed as content should not have anything above 234 white but it does. my plasma if you if the contrast i can get them to all go, but my led/lcd i can go right upto 100 with no issue.
_Dragon_
I got you now, i shall have to have another play with my lcd.
So its not going to affect the picture quality if the contrast is as high as 90. I can turn it up to max without it showing any pink.
scottthehat
nope it will be fine. dont worry.
_Dragon_
So should the backlight be set first before you do the other settings? If i do the other settings first then having the backlight on 33 is easy on the eyes any higher its to bright.
scottthehat
yeah backlight black level then white level.
