Anyone used 'Alternate.co.uk'
Discussion in 'Domestic White Goods Forum' started by Woodymogs, Aug 31, 2013.
  1. Woodymogs
    Woodymogs
    May 20, 2005
    173
    28
    +30
    I'm having to replace my DeLonghi coffee maker and am trying to find the best deal on a new machine. By far the cheapest is ALTERNATE which, tbh, I've not stumbled across before. Looking at the site it would seem to be a Dutch/European based company using a 'co.uk' version for items priced in £s.
    I was wondering if anyone has either heard of them or used them before? The price for the machine is really competitive so I'm tempted to give them a go but could do with some reassurance, or otherwise, about the site. TIA.
  2. Tracey360
    Tracey360
    Feb 6, 2013
    52
    +4
    Have you consider alternative coffee makers? It might be worth reading the Coffee Forum for ideas.
  3. Woodymogs
    Woodymogs
    May 20, 2005
    173
    28
    +30
    Thanks Tracey, hadn't heard of the coffee forums before but will check it out. I didn't use 'Alternate' in the end but got a really good bargain with a DeLonghi from Amazon.de; almost half the price of anywhere in the UK and arrived in four days :)
  4. vertico
    vertico
    Feb 9, 2014
    11
    Sorry about resurrecting an old thread.
    Just wondering has anyone else tried Alternate.co.uk for any purchase?
    I am looking to get a GB-BXi5-4570R Brix Pro from there.
    may thanks in advance
