anyone used a grey screen with the AE100 ??
Discussion in 'Projectors, Screens & Video Processors' started by gizlaroc, Jun 1, 2002.
  1. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,445
    Norwich
    +945
    well the subject says it all really.
    i was in the market for a Barco but there is nothing in my price bracket at the momement , and I am seriously thinking about the AE100 as a stop gap.
    I already have a DA-Lite grey screen, the one with 1.3 gain, that is 60" width , i bought it to use with my plus, which i sold to buy a barco, but somthing happened to the barco i was going to buy.
    what i want to know is whether the panasonic is bright enough to use with this screen ??
    was thinking i could get the panasonic, use it for a couple of months with the screen i have, and when a barco comes along sell it with the screen without too much of a loss.
    but dont want to get one to find i have to buy a new screen too.
    so anyone using a grey screen ???
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,513
    Windsor
    +1,053
    I don't have the projector yet, but I did demo one and played with both white and grey projection surfaces.
    IMO the panasonic is more than bright enough to use a grey screen (in a light controlled room). I had the light intensity set to low and that was plenty, so there is headroom there if needed. Personally I found Ice storm 5 a little too dark (some stars started disappearing in Final Fantasy), so Ice Storm 6 or halfway between 5 & 6 would be fine. That was on low light too.
  3. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,445
    Norwich
    +945
    cheers richard
    that gives me another option then :)
