Anyone use DVI with the Screenplay 4805?
Discussion in 'Projectors, Screens & Video Processors' started by Chazpell, Jan 8, 2005.
  1. Chazpell
    Chazpell
    Hey Everyone
    I have recently bought a Denon 1910 DVD player, and a Infocus Screenplay 4805 projector. Unfortunately, because of the rush for Christmas, I was unable to get a M1-DA DVI cable that I hoped for, so instead I bought a £95 3m component cable, just to tired me over. I have to say, the picture from my point of view is flawless, the only problem being that I can't mount the projector on the ceiling using a component cable this long - its simply not long enough. My best option from here would be to order a long enough DVI Wire, the only problem being that the Infocus 4805 has a slightly different DVI input – the M1-DA. Anyone know where I could get an adapter from, at a reasonable price???? The only place I’ve found is Infocus, but they are way to expensive for me, charging £50 just for a 6” adapter – stupid or what. Thanks for your help.
    P.S. Anyone know where I could sell my hardly used 3 Meter Component Cable ???
  2. daredevill
    daredevill
    Jan 8, 2005
    501
    46
    +156
    yes, www.lindy.com do a adapter from DVI to M1-DA and including postage its £23
    Hope this helps.
