Anyone use Def. Tech BP-1/2X?
Discussion in 'Home Cinema Speakers' started by nathan_silly, Jun 26, 2003.
  1. nathan_silly
    nathan_silly
    I'm thinking about replacing the rears (B&W 601) in a 7 channel system to bipoles, as they are close to the listening position. I have NHT dipoles as sides.
    I can buy Definitive Technology BP-1X or BP-2X for a good price. Poweramp is 100Wx2 into 8Ohm. What shall I go for?
    Retail of the BP-1X were £400, BP-2X £600. He's offering me as ex-demo units, but with full warranty.
  2. paublo
    paublo
    Sep 2, 2001
    169
    South Lanarkshire
    I previously used BP1X's, great little speakers for their size... The BP2X's will have more low down.. but thats what your sub is for...
    Can you not demo them in your system...?
    Paul.
  3. nathan_silly
    nathan_silly
    Yeah he'll let me borrow them for a week.
    I did borrow a set of Jamo Surround 300 but didn't think much of these- I take it the BP-2X have much higher output?
    Amp should be ok.
  4. paublo
    paublo
    Sep 2, 2001
    169
    South Lanarkshire
    I purchased my bp1x's around 4 years ago! the BP2X's didnt come out until after that... they are neat little speakers... I have held onto my pair for a trip into 7.1 when I move to a larger room...
    The bass was fair on them, but I am comparing them to much larger full range speakers.. If they are close to your listening position, then I would definately go for bi/dipoles like the BP1X's...
    When you get them, try them at various heights.. the stock position is very high above your head, I preferred them lower... enjoy!!
    Go for it..
    Paul
  5. nathan_silly
    nathan_silly
    Would using dipoles for sides AND rears be a bad thing?
    If one side is out phase- I guess the middle would cause a hole, or the other side in the corner would.
  6. Jase
    Jase
    Mar 16, 2001
    9,527
    UK
    +925
    If you use Dipoles for both the sides and rears, reverse the phase of the rears. i.e put the Left dipole on the Right and vice versa.
  7. purplepower
    purplepower
    Nov 20, 2007
    Probably a silly question here, but I take it the BP2X Bipoles aren't handed so to speak? - IIRC they don't say anything on the back about Left, or Right but do have a port on only one face of the speaker... :)
  8. leon
    leon
    May 15, 2001
    1,150
    kent
    +67
    i have had the bp1 and bp1x and now i use the bp2x as metioned before they have a little more base than the bp1x they are a good match for the bp8 and 7000 series a great performance from a small speaker . abit of a rubish picture but here they are
    [​IMG]
