Anyone use an IRMan?
Discussion in 'Desktop & Laptop Computers Forum' started by Calzor Suzay, Sep 23, 2001.
  1. Calzor Suzay
    Calzor Suzay
    Apr 24, 2001
    1,590
    63
    Kent
    +199
    I'm looking to dump an old PC under my stairs to act as an mp3 jukebox and run a SB L!ve card off it connected to my Yamaha DSP-A1 via the optical connector but controlling it seems to be my only problem.
    After a bit of digging around the IRMan looks good but not sure if I can extend the box from the puny 1.5m of cabling to about 5m so I can bring it out from under the stairs to my lounge.
    Anyone know if I can extend it or power becomes a problem or any other alternatives or suggestions? I'd like to keep it InfraRed and not hardwired from a control perspective.
  2. GarryF
    GarryF
    Aug 30, 2000
    1,429
    83
    Scotland
    +339
    I have an IRMan, dunno if it would if the cable was extended but I would guess it would.
    If I was you I would try it with an extension cable, if it doesn't work you can always buy some IR repeaters from letsautomate.com which would work.
