Anyone use a PDA as a universal remote
Discussion in 'Home Cinema Control & Remote Controls' started by Eagerbeaver, Aug 8, 2004.
  1. Eagerbeaver
    Eagerbeaver
    Are there any PDAs with the following functions
    1.Strong in built CIR which could be used as a universal remote
    2.Hard buttons can be used for volume control channel changing and power on/off (maybe even launch macros)
    3.Has built in Wifi.
    Is is practical to use a PDA as a complete replacement for a universal remote control.
  2. duncs
    duncs
    I have a Dell Axim 3xi.
    1 - CIR - Yes
    2 - Hard buttons - Yes
    3 - Wifi - Yes
    I am still setting mine up using software from http://www.pdawin.com but it works a treat with what I have done so far. I certainly find it practical considering I can replace 5 remotes with one.
    The other advantage is that with WiFi you can also control your pc to stream video and mp3 to your AV set up. This is a future project for me so unfortunately, I can not give further details on how to do this.
  3. stricko
    stricko
    Jan 20, 2004
    284
    Lambourn
    +4
    Very practical indeed. I'm using an old IPAQ with and IR extender but there are more and more CIR models coming through. Go an have a look at the active community over at www.remotecentral.com. PDAWin is good, but is seems to be a bit short on support. Totalremote is catching it fast... for the real techies, NetRemote will launch a direct IR version soon.....
    Lots of fun!
  4. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    I use an iPAQ 2210 with pdawin as a universal remote and it works fine. I had a couple of problems teaching it one or two of the buttons on the Sky+ remote but apart from that no problems.
    The thing I don't like it that it doesn't seem to support holding a button down (to increase volume for example), you have to press the button repeatedly.
    HTH
    John
  5. FrankW
    FrankW
    RemoteControl II (http://www.avforums.com/frame.html?http://www.avforums.com/forums/showthread.php?t=147014) supports this :)
    Frank
  6. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    I've looked at the website and it doesn't seem to support Pocket PCs yet, is that correct? The big thing I like about pdawin is that is supports Pronto CCF's - will RemoteControl II do likewise?
    John
  7. FrankW
    FrankW
    No, RC II can import only CCF- IR codes, not the panels.
    It has an panel editor included, so you can edit the design on your couch without an PC :)
    Currently only Windows CE handheld PC's with a display sizes up to 800x600 are supported. An PocketPC- version is available in some weeks.
