Anyone upgraded their AX10 to AX10i
Discussion in 'AV Receivers & Amplifiers' started by Ryan, Nov 21, 2003.
  1. Ryan
    Ryan
    If so, does the upgrade only give you the ilink or does it address all the other changes as well.
    For £500 I would hope the latter.
    Ryan
  2. Ryan
    Ryan
    Anyone :confused:
  3. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    ryan,i am sure the upgrade is only the i-link,so dont worry that you have an inferior amp cos you havent! it is not worth £500 just for this imo.if youre happy with it then save cash for more kit.;)
  4. Ryan
    Ryan
    Thanks for the info Dennis. I only have 2 dvd-a so it certainly wouldn't be worth the money.
    regards
    Ryan
