Anyone try recording stuff via the S-video output of the Sky box?
Discussion in 'Sky Digital TV Forum' started by ensyed, Apr 27, 2007.
  1. ensyed
    ensyed
    May 25, 2006
    675
    +6
    I am interested in archiving a few shows via the s-video output of the HD box into the s-video input of a Windows MCE pc to keep on the harddrive. Can anyone comment on the quality.
    I was told on the Windows MCE forum that you cant buy TV tuner cards with component inputs for the UK market...Is that correct?
  2. nheather
    nheather
    Oct 6, 2004
    19,753
    167
    Horsham, West Sussex
    +10,035
    I've not recorded S-Video but I used to have my Sky+ box connected up using this format (because my DVD had my TV's only RGB SCART and daisy chaining didn't work).
    I agonised for some time and kep switching between S-Video and SCART RGB and in the end decided that I couldn't tell the difference.
    So in answer to your question S-Video is about the same as SCART RGB.
    It goes without saying that it only supports SD - so if you archive HD stuff it will be converted to SD.
    Cheers,
    Nigel
  3. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    I am feeding an MCE system via the s-video out from the Sky HD box & then streaming around the house to Xbox 360s used as Media Center Extenders. I have been very pleasantly surprised at how good the picture quality is. The digibox & MCE system are hooked up to the same HD projector so I can do A/B comparison. The digibox is clearly better but the picture from the MCE PC is still quite watchable even on a 10 foot screen. As mentioned this will be SD only but the superior quality of the HD channels does carry over especially on a smaller TV screen.
  4. fraggenstein
    fraggenstein
    Dec 2, 2004
    162
    +12
    I've recorded a few things via the s-video output and like nheather I couldn't really tell the difference between s-video and rgb scart. :thumbsup:
  5. mjcairney
    mjcairney
    Oct 26, 2003
    7,293
    2
    137
    Airdrie, Scotland
    +1,079
    Just one point to remember though, if you use s-video, you'll also need to have an audio connection - could be that I'm :lesson: to the converted and, if so, I apologise.
    Cheers,
    Martin.
  6. Ultra2man
    Ultra2man
    Dec 19, 2003
    1,140
    2
    Biggleswade, Bedfordshire
    +260
    Also do not forget that you will need an audio feed aswell as the S-video feed.
  7. ensyed
    ensyed
    May 25, 2006
    675
    +6
    Thank you. I will try recording something and report back. I am aware that s-video is video only but thank you for the reminder. My TV doesnt have hdmi input so I am already using the component video out from Sky HD.
  8. sizedoesmatter
    sizedoesmatter
    Dec 5, 2006
    375
    +27
    My box is connected to my dvd recorder by S-video/audio to scart. If there is a difference to rgb I haven't noticed it.
  9. avinitski
    avinitski
    Apr 22, 2005
    3,319
    +216
    svideo works fine, use it myself to record from Sky+ to my PC, results are fine.
