Quantcast
Anyone tried Total Remote for Pocket PC?
MattB
I am trying Total Remote with my 2210 but so far it does not seem to be sending any IR. I have it in CCF mode running a file which should control my preamp amongst other things (thanks Phil)
According to the Remote Central forum there is a major update due (V2.1) which should sort out a lot of issues link
Please let us know how you get on...
johndon
MattB,
You seem to be having the same problem as me - it appears to learn the buttons then, when ypu try to use them nothing happens.
I got it to learn the buttons for my Hitachi Plasma this morning and it worked OK but 5 minutes later, the buttons didn't work anymore.
John
MattB
Just a thought but are any other programs, eg Nevo, self-starting and 'stealing' the IR? Have a look in Settings/System/Memory/Running Programs/
johndon
I've tried again and it seems that the problem is down to range (I've got the program set to use the IrDA to send the signals.
I've got my gear in ARCA series 100 cabinets which have speaker cloth in the doors - if I open the doors and sit very close to the gear, the remote seems to work.
It seems strange that the range is so bad as range is one problem I've not had with TV Remote or Nevo.
John
MattB
IPAQ native CIR should give you more range.
