Anyone tried the SB+ from www.at-view.co.uk
Discussion in 'Music Streamers' started by DannyBoy73, Jan 15, 2008.
  1. DannyBoy73
    DannyBoy73
    Jul 24, 2005
    607
    28
    Surrey
    +68
    Has anyone experienced the SB+ (based on SqueezeBox 2 & 3) from http://www.at-view.co.uk/sb2.htm???
    They claim its Audiophile streamer.... Looks a a little bit home made but would be very interested if it does what it says on the tin!
  2. Druboo
    Druboo
    Apr 1, 2006
    882
    46
    Cotswolds
    +130
    I think Mr_Sukebe has one.
    Tends to hang out in the Hi Fi Forum. Might be an idea to PM him for an opinion :smashin:
    HTH
  3. Mr_Sukebe
    Mr_Sukebe
    Mar 10, 2004
    2,397
    London
    +214
    You called?
    I'm not sure what you want me to say about it.
    It's basically a re-bodied SB3 on steroids. So it's housed in two seperate boxes, the control unit and DAC in one, the PSU in the other, joined by a supplied bundy cable. The PSU appears to be massively overspecced (a good thing). The control unit has uprated clocks and the DAC circuit looks like a purpose built piece of kit (not small). It has standard RCA/phono outputs and a single BNC digital output.
    As the main element is still an SB3, functionality, upgrades are all the same as an SB3.
    I've personally compared mine to a variety of kit and believe that on sound quality, that it's roughly on par with a dedicated CDP costing around £1500.
    It superceeded a modded Meridian 500 transport with a Bel Canto DAC2, each of those units individually cost £1300 new.
    Hope that helps.
  4. DannyBoy73
    DannyBoy73
    Jul 24, 2005
    607
    28
    Surrey
    +68
    Hi cheers for the info, much appreicated.
    I used to have the 500 Transport and upgraded it to the Meridian 596. If its in that ball park then I think I might have to try it.
    Have you tried it with vs without an external DAC? I've got a Meridian Processor with I think a very good DAC built in. I'd be interested to compare vs the SB+'s DAC.
  5. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    Don't forget the Transporter, it has the better PSU and hi-end DAC. Plus it has the CPU to run 24/96 hi-rez material; a s/w update should give native support for 24/88.2 (e.g. Linn Records studio masters)
  6. DannyBoy73
    DannyBoy73
    Jul 24, 2005
    607
    28
    Surrey
    +68
    Ah, does the SB+ nor Squeeze box 3 support 96 or 88.2 material??
    Do we think more and more material will come along in this format?
  7. Mr_Sukebe
    Mr_Sukebe
    Mar 10, 2004
    2,397
    London
    +214
    I've never heard a transporter, but other comments I've read on the net infer that the SB+ has the edge on sound quality.
    Having said that, the transporter does have the advatages of digital inputs and can support formats above 24/48 (24bit, 48khz). There's very few groups selling those files as yet (Linn being one), but chances are that they'll be more prevalent in the future.
    When I first got the SB+ I used it with my old Bel Canto DAC2, which IMO is a very good DAC. The SB+ was very similar in all areas but the bass, and in the bass, it was better controlled and timed than the BC DAC2.
  8. dogma6
    dogma6
    Aug 20, 2003
    253
    28
    +27
    Hi There,
    How much is the SB+?
    I'm going to be buying my first squeeze box soon :) I've got some old Arcam kit at the moment (Arcam Alhpa 8 Amp and Power Amp)
  9. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    >How much is the SB+? <
    Reckon on spending a bag of sand
  10. Peter314
    Peter314
    May 13, 2007
    316
    28
    +36
  11. JonnyBingham
    JonnyBingham
    Apr 14, 2008
    216
    Guildford
    +10
    What are people's opinions on whether they think the sb+ does away with the need for a cd player? would the sb+ sound better than a wadia 170i with lavry da10 do you reckon?
    And how heavy are the 2 boxes?
  12. Mr_Sukebe
    Mr_Sukebe
    Mar 10, 2004
    2,397
    London
    +214
    The control box is pretty light, as it's got very little in it, i.e. the motherboard from the SB3 and the new DAC motherboard.
    The PSU has a toroidal transformer that pretty much fills it's box, so that's quite heavy.
    As for comparisons with your 170/Lavry, well I've never heard them, so would be rather presumptious to comment.
    At-Tunes are happy to run a home dem, that would be my suggestion.
    If you asked me to guess based upon other DACs I've heard, then I'd guess the SB+ would probably have the edge, but not by a massive amount.
