Anyone tried Surround Amp Front-L/R pre-out to Tube Amp aux-in when watching movie ?!
Discussion in 'AV Receivers & Amplifiers' started by AVJ, Jul 22, 2004.
  1. AVJ
    AVJ
    Dear all AV Forums friends !
    I owned a Marantz SR7000 Surround Receiver, and a Houston Mini-2 Tube Amp.
    Will I gain any benefit (in sound quality), when connecting the Surround Receiver's Front-Left/Right channels pre-out to the Tube Amp aux-in ?
    (note : my Tube Amp do NOT has any power-in or processor-in, just ordinary aux-in, cd-in)
    i.e. the signal path will then be :-
    DVD Player (Philips 963SA) digital-audio-output ===> Surround Receiver (Marantz SR7000) Front-L/R pre-out ===> Tube Amp ===> Front-L/R speaker (KEF Q50)
    --- of course, the remained channels (Center & Rear) will still be driven by the Marantz.
    Will the above idea improve the overall sound quality ??!
  2. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    I don't use a tube amp, but use exactly the same arrangement taking the front pre-outs and taking them to a line in on my Linn amp/s.
    This has a twofold improvement; firstly there is an improvement in front channel reproduction, secondly it allows me to retain a 'pure' two channel system too in the same room to play CDs through rather than through my AV amp.
    A slightly oblique answer I know.
    I guess if your valve amp is powerful enough and your mains are efficient enough then you shouldn't have a problem, the only concern might be if your amp/speakers can't reach Dolby reference level in your room (105db), but then again that may only be an issue if you listen anywhere near those volumes.
    HTH
