Anyone suggest a H/U.
Discussion in 'Video Streaming Boxes & Services' started by trashbat, Mar 19, 2006.
  1. trashbat
    trashbat
    I'm looking to upgrade my headunit to a DVD unit with a motorised screen. Has to be all one single unit though. How much are they too ? £600 is probably my limit.
  2. pjlfc
    pjlfc
    Aug 5, 2005
    17
    3
    only all in one i can think of is the Pioneer AVH-P5700DVD.No hideaway brain.
    I am thinking of buying the Kenwood KVT627,which has the hideaway but is supposed to be better quality and plays Dvd mp3,whereas the Pioneer is a bit more picky.
    Theres about £30 difference on Ebay between them.
  3. themovingunits
    themovingunits
    I have the alpine D-310 it runs about 1200 american dollars and i can't imagine a better system
  4. Krystal-ice
    Krystal-ice
    if your limit is £600 then you can go for the following models:
    Kenwood KVT-627DVD
    Both very similar in quality.
    You can go for cheaper units around the £400 mark but the quality is much lower.
    Above your limit i would go for the PIONEER-AVIC-X1R, which you can now get for under £1000, even as low as £850. This unit has screen,dvd,cd,radio and built in SAT NAV
