Anyone suggest a company to design/build pole mounts?
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by vk2003, Dec 18, 2006.
  1. vk2003
    vk2003
    Feb 7, 2005
    422
    Camberley
    +11
    I need two specifically designed pole mounts to hold 15" LCDs.
    The mounts need to be some thing like this one here but the problem with this is that the joints are freely mobile.
    Since the pole to which they attach iteslf moves in an arc, this mount will cause the monitor to move on the mount by centrifugal force, and possibly be damaged by bumping into other equipment.
    Anyone got any ideas of a company that could build something for me, or seen something else suitable? Extensive googling has not really produced anything useful
  2. lone ranger
    lone ranger
    Nov 20, 2006
    883
    +35
    try unicoil,you give em the model of tv,they build you your mount.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,927
    The Borders
    +3,572
    Hello vk2003
    First off I'd suggest if the monitors are likely to be bumped into then they are in the wrong position and you need to alter your plans!
    If they are bumped into then some damped movement may be preferable to no movement - which is likely to result in damage to either the Display or the person bumping into it!
    The E-vision range are very good and well damped - see http://www.e-visionuk.co.uk/
    Best regards
    Joe
  4. vk2003
    vk2003
    Feb 7, 2005
    422
    Camberley
    +11
    Do you have any contact details for the above please? Googling them simply comes up with a saudi company!
  5. vk2003
    vk2003
    Feb 7, 2005
    422
    Camberley
    +11
    Joe,
    Thanks for the link. I will call them tomorrow. I agree that a damped system is what I need. The position of the monitors is to be connected to a Dental chair, and hence the possibility that it could be bumped, as the arm to which it connects rotates around the chair. Hence the concern about centrifugal force...
    Vishal...
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,927
    The Borders
    +3,572
    Hello Vishal
    I did wonder what you were up to - having seen a few 'flown' displays in dentists surgeries in the past.
    Usually Unicol will not work to a drawing and will insist you ship a sample Display - unless they have already made something to suit your Display.
    See htpp://www.unicol.co.uk
    Best regards
    Joe
  7. vk2003
    vk2003
    Feb 7, 2005
    422
    Camberley
    +11
    Thanks again Joe!
    Vishal...
