Anyone seen this before - it's cobblers surely?
Discussion in 'Movie Forum' started by SanPedro, Dec 11, 2002.
  1. SanPedro
    SanPedro
    Jan 11, 2001
    4,536
    +521
    DVD copying anyone? On CD? surely not... This link came through on my inbox.
    see here
    http://www.copydvd.net/
    (must be a fast one)
  2. lentini
    lentini
    Jun 28, 2002
    3,592
    Dog Eater
    +463
    it's basically a DVD ripping program which creates SVCD's
  3. SanPedro
    SanPedro
    Jan 11, 2001
    4,536
    +521
    So it won't fit a DVD film onto a CD then? Or does it compress it somehow?
  4. lentini
    lentini
    Jun 28, 2002
    3,592
    Dog Eater
    +463
    SVCD's use MPEG2 compression and can fit about 40mins of video on a CD.
    So you're looking at 2 or more CD's
  5. Jamsie
    Jamsie
    Or it's the one that will rip the movie off the DVD to your HD and (with a bit of fichering about) convert it to a Divx;-) file which will fit onto 1 normal cd-r.
    On the subject of Divx;-) i see Scan have started selling a DVD player which supports the format!
    http://web6.scan.co.uk/Products/Info.asp?WPID=46005
  6. Steve J Davies
    Steve J Davies
    Dvd rippers that use mpeg4 can get quite a lot of 'footage' onto a CD. It depends on the complexity (amount of data) of the original movie and how far you mix your sound track down.
    I played with this and got my copy of twister into a single CD and its very watchable at full screen resolution on the pc.
    You can always choose to spread the resulting film over 2 or more cds to improve quality.
    It quite straightforward to do if you pick the right software and follow the instructions - some of it contains spyware that you should disable at your firewall. Codecs aplenty out there.
    Steve
