Anyone recommend a surround sound system?
Discussion in 'Home Cinema Speakers' started by Ahoy, May 8, 2007.
  1. Ahoy
    Ahoy
    Apr 30, 2007
    Hi folks, I have a Samsung LE32R87BD TV and a HD DVD player and am considering some sort of surround sound sytem to go with them. The models i've seen seem to have a DVD/CD player built in but I don't need this - do I simply need an amp and a series of speakers / woofer?
    Any good deals out there or any particular recommendations? Any advice gratefully received!
    S.
  2. Abbeygoo
    Abbeygoo
    Oct 19, 2005
    25,021
    Manchester
    +10,165
    I would say with you having a HD-DVD player already there is little point in getting a system that includes one. Do you already have an amp / receiver at the moment? What budget do you have? How big is your room?
  3. Ahoy
    Ahoy
    Apr 30, 2007
    The room is approximately 5metres long by about 6metres wide but 'L' shaped. The only amp I have is from an old stereo unit - apparently it is (was)a 'good one' - about 10years old - made by NAD! I don't actually know what a receiver is and budget is going to be, preferably, low hundreds but we're open minded as quality is paramount.
    Cheers,
    S.
  4. Abbeygoo
    Abbeygoo
    Oct 19, 2005
    25,021
    Manchester
    +10,165
    I strongly recommend www.creative-audio.co.uk as their website is superb. Gives you loads of options and choices and is very well laid out - their customer service is second to none as whatever time day or night you send an email you usually get a response pretty quickly!
    For starters, as your room is a decent size, have a look at this combination - fantastic value and performance.
  5. Ahoy
    Ahoy
    Apr 30, 2007
    Thanks, that gives me something to get my teeth into!
    S.
  6. sk8
    sk8
    Sep 19, 2006
    556
    B&NES
    +17
    another vote for creative audio
