da_murphster
Established Member
Hi all, not sure if this is in the best forum to ask.
I'm looking to recess my LG OLED65C8PLA into the wall.
I am tight on space so will either box it in very tightly or even just box in the 'gubbins' so its recessed about 90% IYSWIM.
Either way I will have very limited access to the rear of the TV once its up so was looking to use a cantilever mount so I can pull the TV out a bit if I ever need to remove it or get access to the ports.
All the cantilever mounts I can find are minimum depth 60mm or so, I'm keen to reduce this as much as possible. Slimmer = less smashing up of my wall!
I also don't need the 'features' of most mounts - just the simple ability to be able to pull it out straight by a couple of inches.
Anyone recommend a slim cantilever mount?
