Anyone recommend a low budget lcd projector?
Discussion in 'Projectors, Screens & Video Processors' started by Mottok, Jan 11, 2012.
  1. Mottok
    Mottok
    Jan 11, 2012
    72
    +6
    Hi - after buying and returning a HD600X-LV DLP projector due to really bad rainbow effect I am looking for help finding a good LCD projector. I can't seem to find any decent reviews for LCD projectors under around the £800 - £1500 mark but my budget is more like the £400 - £600 mark!
    Amy suggestions appreciated - looking to play movies and ps3 a couple of times a week so minimum 720p I guess and the quieter the better! Cheers.
  2. kbfern
    kbfern
    Aug 17, 2002
    17,907
    Wolverhampton
    +6,060
    Epson EH-TW450 review | Expert Reviews
    The only new 720p lcd that is in your budget range is the Epson TW450 which should be available for around £500.It has no lens shift though which for an LCD is unusual however neither does the Optoma so that should not be a problem to you.
  3. Mottok
    Mottok
    Jan 11, 2012
    72
    +6
    Hi thanks for that - yip there's not much for my budget, thinking maybe a plasma would be a better idea, if the tw-3200 would only come down to around £600 I'd be laughing.
  4. kbfern
    kbfern
    Aug 17, 2002
    17,907
    Wolverhampton
    +6,060
    You could always get a second hand TW3200 I have seen them go for £600 approx with only low hours and still 2+ yrs warranty remaining.
  5. LightBright
    LightBright
    Jan 12, 2012
    100
    +3
    I have a TW-480 and it's really good. Comparable to DLP in brightness. The lack of lens shift did surprise me a little, but it has extensive keystone correction so it's not really a problem. Unless there's some disadvantage to doing that which I'm not aware of?
  6. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    You are now, in your other post! :D
  7. revs
    revs
    Aug 23, 2007
    39
    Where would one find these second hand ones? In the classifieds/ebay?
  8. woppy101
    woppy101
    Sep 12, 2008
    3,909
    +2,367
    You could try epson them selfs they offered me a box damage unit for £720!i did exactly the same as you and bought the optoma but couldn't stand the rainbows,I managed to get a TW2900 for £550
  9. Mottok
    Mottok
    Jan 11, 2012
    72
    +6
    Did you just phone them or have you got an email for them - good idea, thanks!
  10. woppy101
    woppy101
    Sep 12, 2008
    3,909
    +2,367
    I phoned them
  11. Mottok
    Mottok
    Jan 11, 2012
    72
    +6
    Ok - what would you recommend between the tw450 or the tw480?
  12. woppy101
    woppy101
    Sep 12, 2008
    3,909
    +2,367
  13. Mottok
    Mottok
    Jan 11, 2012
    72
    +6
    Because? :D
  14. woppy101
    woppy101
    Sep 12, 2008
    3,909
    +2,367
    Newer model
  15. Mottok
    Mottok
    Jan 11, 2012
    72
    +6
    Fair do's - wonder if the technology is improved, off to compare, cheers.
