Pizzalover1
Looking for a indoor aerial for the bedroom
What you've spent money on a TV for the bedroom and don't want to get decent results from it?Looking for a indoor aerial for the bedroom
Much getter to get a feed from your existing (outdoor) aerial
2. Is the Indoor antenna placed near the outside wall? Yes - Good.
I would just add that most modern houses have a metal foil layer in the wall as part of the thermal insulation. The result can be a passable imitation of a screened room as far as radio waves are concerned!
In practice this means that an in-room aerial probably needs to point through a window in the direction of the transmitter.
Alan
Impossible to make a useful suggestion without knowing your postcode or at least the name of your local transmitter.Looking for a indoor aerial for the bedroom
winston2010's cavaet should be heeded!But, if you must, no guarantees however:
Telecam TCE2000 LTE Indoor Aerial TV Antenna: Amazon.co.uk: Electronics
Don't, whatever you do, go for an amplified one. You can't amplify what is not there
