anyone recommend a DTS amp for under £450 ???
Discussion in 'AV Receivers & Amplifiers' started by SDK 2001, Jun 2, 2001.
  1. SDK 2001
    SDK 2001
    Can anyone recommend a DTS amp for less than £450 ??
    I have a Sony DVPS7700 DVD Player so the Amp has be silver or champagne colour.
  2. paiger
    paiger
    CHeck out the Sony 940 available from Empiredirect.co.uk for £400. It's available in silver and the remote will work your dvd player and other stuff too. It sounds great and has loads of useful features. Best bit is an analogue direct feature so you can plug your player into the CD phono in's and play cd's with no processing. Then you have a co-ax cable for the digital and have all the processing for dvd's
    Check out the review on this site. It's not the newest amp but you won't be dissapointed.
    Steve
