Anyone recommend a DLP Projector circa £1k that does the following?:
Discussion in 'Projectors, Screens & Video Processors' started by DaveH, Jun 21, 2005.
  1. DaveH
    DaveH
    Aug 1, 2000
    678
    Surbiton, Surrey
    +20
    Hi all,
    I decided that I need a projector and would prefer a DLP projector. My main purpose of this post is to determine what I could get for around £1000, and if possible to have many (hopefully all) of the following features on it.
    If anyone could comment on my proposed budget or their experiences it would be very helpful.
    Desired projector:
    One that has a 16:9 feature.
    One that has a suitable digital connector like DVI for HTPC.
    One that has HDMI for Sky HD. (Not sure if this is possible with a DVI).
    One that is HDTV compatible.
    So what is possible here?
    Thank you.
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    You won't find a HD capable DLP at around 1K, the newly released Benq 7700 I think is the cheapest - lot of gossip about it on this forum...PJ :)
  3. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    521
    North Cotswolds
    +3
    I know you've mentioned DLP but personally I would also consider a LCD at that price, e.g. Panasonic AE700
  4. Jenn
    Jenn
    Apr 8, 2005
    6,894
    +1,260
    The Themescene H30A seems to be your answer. It's DLP for about £1000.
    It has:
    HDMI (DVI HDCP connector via optional adaptor)
    DVI (DVI-I HDCP connector)
    Component Progressive & Interlaced (2 Inputs: 3 x RCA & DVI-I with supplied 3x RCA to DVI-I adaptor
    SCART RGB (DVI-I via supplied SCART to VGA & VGA to DVI-I adaptors
    S-Video (Mini DIN)
    Composite (RCA)
    And according to the manufacturer it's HD compatible.
  5. DaveH
    DaveH
    Aug 1, 2000
    678
    Surbiton, Surrey
    +20
    That's quite a good buy even though it has to make use of scaling due to it's native resolution of 854 x 480 to get HD.
  6. badgerboy
    badgerboy
    Apr 14, 2003
    37
    9
    Kingston Upon Hull
    Thats like saying a 50cc motorbike is "Motorway Compatible" - it is, but you'd have to be daft to try it.
    HD by definition should have a minimum of 720 lines....
  7. binbag
    binbag
    Jun 16, 2004
    1,694
    +81
    Whilst I broadly agree with the above post the Screenplay 4805 fits the original posters description. We've been told the key to Sky HD will be HDCP compliance. DVI-D can do this depending on the age of the PJ. Anything new should, but always ask at the demo.
    And the important thing - lovely PQ at the price point.
  8. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,583
    Stoke
    +55
    I may be selling my HS50 Sony for £1000- 1100 soon, to get a H78
    Would you be interested?
    Hi Def is stunning on it :D
  9. Steve Middleton
    Steve Middleton
    Have you heard of the Sharp XV C90E? It's the same as the 91 but without the short throw lens. I have one myslef and think that it is brilliant. It's only 3 months old and I don't have sky so only use it for watching dvd's. I am heading back to NZ soon and need to find a home for it. Don't know if you would be interested. I can even get the short throw lens for it.
    :thumbsup:
  10. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,056
    The Borders
    +2,525
    Hello all
    The ThemeScene H30A ticks all the boxes - if you stick to the recently introduced EU guidelines its 'HD Ready' in that it accepts and displays 720P and 1080i Digital signals at 50Hz and 60Hz and is HDCP compliant.
    As others have said its not a Native HD resolution DLP so has to down convert any HD signals to fit its SD panel - though you can still tell your watching something that's much better than SD.
    The ThemeScene also includes the 3 Year Onsite Warranty pack - another great feature.
    Best regards
    Joe
  11. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    I think that's way underestimating how good HD looks on SD screens, you don't get the full 720p resolution but you still get the massive bit rates for a picture that will look significantly better than DVD.
    I would say it's like saying a CBR600 is a racing bike. Won't do much against a Fireblade, but it's still fast as **** and cost half the price.
  12. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    DaveH
    The H30a is indeed an impresive little machine. If you're sitting about 2 x screen width away from the image, you may not notice the lack of resolution but the pj is excellent value at £1000.
    If you need to sit much closer than 1.85 x then the screendoor may start become visible and then a higher esolution projector would be a better option. LCDs have larger gaps between pixels compared to DLP so you may have to demo before buying (DLP is 88% image/pixels, 12% gaps, LCD is around 50 to 60% image, and the rest is gaps - though some use various forms of 'smoothscreen' technology to hide it).
    Gary.
  13. DaveH
    DaveH
    Aug 1, 2000
    678
    Surbiton, Surrey
    +20
    Thanks for all the interest everyone.
    Okay so if I increased my budget to get a projector that is TRUE HD compatible would you all recommend the Benq 7700 as mentioned above?
  14. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
