anyone ported to orange ip4 sim only? problems
big-al123
ported number from voda to orange
hi,
i took out a sim only deal with orange and seem to be having trouble.
i can no longer log in to my account since my numbers ported over?? as you have to enter your telephone number online to view the account, and also i can no longer log into bt openzones since the port.
i ported from vodafone to orange if its any help?
has anyone else ported a number across to orange, and did you have any problems please? all worked ok with the number orange gave me, but its been hell since i got my voda number ported. so much so im considering going back to voda already, i never had any hassle with them.
why the problems?? they say they can port a number so they should be geared up for it. you should have full access to all services after the port surely.
fed up with it now.
please help
jonnyp25
I had the same problem, I had to ring orange porting team and they created a new account with my old number. Since then it works fine. Just ring the porting team and ask them to make a new account so you can log on with your old number.
big-al123
does the account app work ok now? showing data used etc.
and bt openzones?
was yours all sorted in one phonecall, as i am fed up of phoning them................weird!
cheers
Trending threads
