Anyone know
Discussion in 'Satellite TV, Sky TV & FreeSat' started by paiger, May 31, 2001.
  1. paiger
    paiger
    Where I can get some good quality double screened downlead for my tv aerial. My cable is about 25 years old. All I can see is low-loss stuff.
    S
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,217
    +3,073
    Go to B+Q or Homebase or a local aerial installer. Buy some CT100 or equivalent co-ax. If you are feeling really flush you could use CT125 instead... it's available in "external" or "internal" versions. The external on eis very thick and you'll find it very hard fitting any co-ax plugs or sockets directly to it.
    Hope this helps.
    Gordon
  3. paiger
    paiger
    Cheers Gordon.
    S
