Anyone know who makes this plasma from Aria?
Discussion in 'Plasma TVs' started by Dillz, Apr 1, 2005.
  1. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    Just wondering if anyone knows who makes this plasma that Aria are supplying which is currently on their home page at aria.co.uk priced at £1173.83. What is pixel pitch? Can't be resolution can it at 1101 X 1080
    Here are the specs;
    Manufacturer : ARIANET
    Model Number : Arianet 42" Plasma Display Panel
    Audio Out External Speakers Connectable, RCA
    Brightness : 1000cd/m2
    Dimensions : W 1210 x H 640 x D 130 mm/ W 1210 x H 701 x D 210 mmw/stand
    Displayable Colours : 16.77 Million
    Image Aspect Ratio : 16:9
    Image Contrast Ratio : 2000:1
    Inputs : din 4 pin, RCA, Scart input, d-sub 15 pin, RCA
    Pixel Pitch : 1101 x 1080
    Resolution Capabilities : VGA, SVGA, XGA, SXGA, UVGA, UXGA, DTV(480i, 480p, 720p, 1080i)
    Speakers : 2 x right/left channel speaker integrated
    Supporting System Input : PAL, PAL-M, PAL-N, NYSC, NTSC4.43, SECAM
    Viewing Angle : Over 160 degrees horizontally and vertically
    Weight : 48 KG
  2. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    117
    +3
    Most likely a obsolete/surplus panel from Korea (LG/Samsung), like found in Techwood, Goodmans, Tiny Etc.
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Have a look at www.tiny.com and see if you can spot the difference. The numbers are different for sure, but externally they are a dead spit. Buy at your peril, see Tiny thread.
  4. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    i see they do the samsung 63" at £9600 :D
    found them as a company very good for pc's - they in fact built my system to spec (not designed by me of course)
  5. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    Thanks for the replies. I see what you mean about Tiny Maw. It was more the resolution that got me curious.
    A mate of mine is interested in a budget plasma, though personally I can't see why anyone would risk their cash on an unbranded screen when you can get a PW7 or similar for just a bit more. I guess there are a lot of people out there that don't bother to research their purchase.
    @Samjet - So are you tempted then :D :D :D
