anyone know of this sub?
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by backtothefuture, Feb 8, 2003.
  1. backtothefuture
    backtothefuture
    HERE
    was thinking of getting one for my ICE
    anyone have experience with em>?
  2. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    It looks as though it may be an 'Perfect 12' which is housed in the enclosure.If it is i'd say go for it as a mate had a Perfect 10 in a sealed enclosure which was a fine sub and iirc it cost him around £80 for the speaker it's self.
  3. backtothefuture
    backtothefuture
  4. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    Go for it, that is a Infinity Perfect 12, they are great sounding subwoofers.
    I got the Perfect 10 when it first came out and it is still sounding great over 2 and a half years later.
    Give the sub a good amount of power to shine, I recommend about 400 watts rms.
    Any questions just ask.
  5. backtothefuture
    backtothefuture
    its only rated at 300rms :)
  6. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    The advertised 300 watt rms is a very conservative rating.
    I have run the Prefect 10 with 280 rms and it can take quite a fair bit more.
    In the original Infinity white papers the Infinity Perfect 10 and the 12 were powered with 350 and 400 watts RMS amplifiers, I have known people use up to 600 wrms on tap this works fine, as long as the power is was clean, max excursion was watched and the enclosure used was not bigger than 1 cubic foot.
    400 watts RMS should be right for decent clean SPL's of around 125-135 db from 20hz to 80 hz in most cars depending on the cars transfer function.
    In general as a sealed enclosure gets bigger the power handling of a subwoofer falls but low bass extention is increased.
  7. backtothefuture
    backtothefuture
    what kind of an amp would you recommend for the beast then ? :D a link would be cool :smashin:
  8. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    Do you need an amp ? ;)
  9. backtothefuture
    backtothefuture
    that would be quite useful :hiya: unless they forgot to mention its 'active'
  10. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    How much are you willing to spend on a subwoofer amplifier?
    An amplifer which provides 400-500 rms will normally set you aound £250-£350.
    You want a amplifer that puts out decent power at 4 ohms normally this would be a two channel amplifier bridged to mono.
    I have found these at the Car Audio Direct website, these amplifers would be the ones I would consider for some good output.
    A Directed 2400 for £279 pounds.
    http://www.caraudiodirect.co.uk/shop/acatalog/CAD_Amplifiers_303.html
    OR
    A Lightning Audio s2.400.2 for £259.
    A Lightning Audio s2.600.2 for £359.
    http://www.caraudiodirect.co.uk/shop/acatalog/CAD_2_Channel_397.html
    OR
    Rockford Fosgate Punch 500S for £299
    Rockford Fosgate Power 350S for £299
    Rockford Fosgate Power 550s at £349.
    http://www.caraudiodirect.co.uk/shop/acatalog/CAD_2_Channel_76.html
    If you have any other questions or queries don't hesitate to ask.
  11. backtothefuture
    backtothefuture
    :eek: I was already going to get a Phoenix Gold QX300.1 4 channel to power my front 17cm comps and rear 17cms...
    do you mean I need one of those amps (that you gave a link for) just for the sub itself!?
    I've been told to use a crossover with the h/u and to use the Phoenix Gold to power the fronts and bridge it for the rears/ sub
  12. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    You can bridge the rear channels of the amplifier, but doing this does not really give the power to run both the rear speakers and the Subwoofer to anyway neer their potential.
    You also run into problems with the sensitivity difference of the rear speakers and subwoofer.
    The subwoofer will sound much better with a dedicated amplifier.
    To get the most out of your sound system you need a 4 channel amplifier for front and rear speakers, and a seperate subwoofer amplifer for the subwoofer.
    If you want matching Phoenix Gold amps for both speakers and subwoofer, a Phoenix Gold QX350.2 would power the Perfect 12 nicely at £259.
  13. backtothefuture
    backtothefuture
    actually , I was going to use my Alpine 7894 h/u to power the rears with a crossover and let the Phoenix Gold handle the fronts and sub... how does that sound?
  14. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    you might want to try these guys
    http://www.cel-direct.com/
    i bought my headunit off them last year, their prices were AT LEAST £100 cheaper than elsewhere. I ordered on a friday lunchtime and the headunit was at my door at 7.30am the next morning. They also answer emails fairly quickly.
  15. backtothefuture
    backtothefuture
    great link mate :smashin:
  16. James45
    James45
    Sep 21, 2002
    2,844
    59
    the Alpine V12 500w sub amp looks very tasty at £264 or maybe the 700w:eek: :eek: Rockford for £299.
  17. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    You can do it that way but the headunit may distort the rear speakers at a reasonable listening level.
    A dedicated amplifier for sub will sound better if you can get one.
  18. backtothefuture
    backtothefuture
    why should i go for an amp for a decent output at 4ohms as opposed to 2 ohms? ie what difference does the ohms make if power output is the same?
  19. James45
    James45
    Sep 21, 2002
    2,844
    59
    it means you can run another set of speakers in series (or is it the other one) safely. some of the better amps run "half ohm stable" which means you could run four stereo pairs off of one stereo channel.
  20. backtothefuture
    backtothefuture
    ok this is what i got so far:
    Alpine 7894RB h/u with CD changer ; Boston Acoustics FS60 front components (with crossover); I have a pair of Kenwood components that I am only going to use the midrange of for the rear speakers; Infinity Perfect 12 SUB
    in terms of amp I'm going for a Phoenix Gold QX300.1 4 channel and intend to run all 4 speakers of it , using the crossover for tweeters infront.
    interms of 2nd amp i'm thinking of going for the same but in a Mono version , or should I go for an Alpine V12 300RMS? :confused: .. I don't need a crossover for my amp do I??
  21. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    When wiring subwoofers in series it increases the ohms load and reduces the power provided by the amplifier, wiring in parrellel decreases the ohms load and increases the power from the amplifier.
    An amplifer is rated to certain ohm level either in a stereo or bridged mode.
    So an amplifier which is can run 2 ohms in stereo can be run safely in bridged mode at 4 ohms mono.
    If you ran the said amplifier at either 1 ohm stereo or 2 ohms bridged mono it would cut out and possible burn/catch fire.
    Good monobloc (single channel) amplifiers are often very flexible, they can give greater power into lower ohm loads safely (e.g. 1/2 ohm stereo and 1 ohm bridged mono), so a big mono amplifier can run 300 RMS to single 4 ohms subwoofer, or 600 RMS to two subwoofers wired in parrellel to 2 ohms or 1000 RMS to three 4 ohm subwoofers wired in parrellel to a 1.33 ohm load.
    The Infinity Perfects are 4 ohm subwoofers so you want an amplifier that give most of its power at 4 ohm.
    Normally for 4 ohm subwoofers this is 2 channel amplifier bridged to 4 ohm mono, the perfect amp would be the Phoenix Gold QX350.2 or if you are on a budget the Alpine V12 MRV-T420 at £169.99 at cell-direct will sound pritty good.
  22. James45
    James45
    Sep 21, 2002
    2,844
    59
    jeez no wonder I failed physics:D
  23. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
  24. James45
    James45
    Sep 21, 2002
    2,844
    59
    very handy cheers:smashin:
  25. backtothefuture
    backtothefuture
  26. backtothefuture
    backtothefuture
    can u guys recommend a good PUNCHY sub for chart/pop music and rock ?
    I tried out the Infinity Perfect 12 in my existing setup and find it a bit lethargic... hence am having it returned ...
  27. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    Something doesn't sound right here :confused: What amp did you use to drive it ?
  28. backtothefuture
    backtothefuture
    well to try it out in my existing ICE, I think it was the Radiomobile 4 channel , bridged since the Kenwood PS150 was busy driving the front component speakers :confused:
    I did put back my 10" Kenwood in there and it sounded a bit better
    :confused:
  29. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    Can you supply a link to this amp ?
  30. backtothefuture
    backtothefuture
