Anyone know of a device to transmit IR signals?
Discussion in 'Home Cinema Control & Remote Controls' started by Bushwacked, May 5, 2005.
  1. Bushwacked
    Bushwacked
    My kit is housed in a cupboard under the TV and at the moment I have to leave the door open to get the remotes for the AMP, DVD and FREEVIEW box to work.
    I've seen devices in a hotel that allow a remote sensor to pick up the IR signal from whichever remote is being used and transfered to the device which is hidden elsewhere and out of sight of the remote. I can't find what they are called to do a search to find out where to buy them...
    Thanks for your help in advance.
  2. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
  3. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Take a look at www.Keene.co.uk and their IR Remote Extenders under the Products menu. I have exactly the same as you, amp and freeview in a cupboard, and this box works a treat. Plus you can get extra cables later.
    Richie.
  5. Bushwacked
    Bushwacked
    Excellent, this is just what I am looking for, thanks.
  6. gingerone
    gingerone
    Dec 10, 2002
    2,567
    +388
    I was just about to post a thread to ask the same question.
    Excellent.
  7. sy278
    sy278
    Jul 4, 2004
    510
    28
    Glasgow
    +40
    one for all also do a version which can usually be purchased from either Argos or Index.
