anyone know of a 1 phono plug to 2 phono plug lead?
Discussion in 'Home Cinema Speakers' started by Ewok, Jun 15, 2001.
  1. Ewok
    Ewok
    I need a 1 phono plug to 2 phono plug lead, anyone know of a good one?
    It's to connect the subwoofer phono on my dvd player to the left and right input on my subwoofer, because my dvd doesnt have left and right for the sub, just a single plug, and it needs something plugged in both left and right on the sub or it wont work, so I need a 1 phono plug to 2 phono plug lead. Cant seem to find any
  2. Del
    Del
    Nov 15, 2000
    782
    Berkshire
    +16
    Ewok
    Have you tried maplin electronics? :)
    web page
    Del
  3. Desmo
    Desmo
    Jan 4, 2001
    14,192
    Braintree, Essex.
    +5,870
    How about the phono adapter here
    It's a phono socket doubler. Plug this in to your DVD player then run 2 cables to the sub.
  4. Leon Rees
    Leon Rees
    The LFE coming out of your DVD is a single, mono channel...
    Just use the left input on your sub... the stereo inputs on the sub end up mono-ing the signal. No need for a splitter
  5. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    As I replied in your post in Amps and Receivers, you only need a single lead.
    As it shows in the manual
