anyone know much about the Onkyo TX-SR674E ?
Discussion in 'AV Receivers & Amplifiers' started by nathan1977, Apr 23, 2007.
Tags:
  1. nathan1977
    nathan1977
    I'm after a upscaling receiver and am looking at the Sony 3200ES, 5200ES or the Onkyo TX-SR674E. Upscaling from component and hdmi is important.
    Any thoughts?
  2. dowzer
    dowzer
    Oct 21, 2006
    1,658
    +252
  3. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    do you mean upscaling or upconverting? upscaling means altering the resolution of the picture, upconverting simply means changing from one type of connection method to another (ie from s-vid to HDMI or from composite to component etc)
    of the sony's only the 5200 does both, the 3200 does upconverting...
  4. nathan1977
    nathan1977
    HI,
    I mean't upscaling as in taking the inputs and upscaling the resolution to make it more acceptable on a HDTV
  5. bairdyboy1980
    bairdyboy1980
    Aug 14, 2005
    4,457
    West coast style, Scotland
    +345
    Yep your right. the 674 only converts to hdmi and doesnt upscale. Its really so you only need to run one cable to your LCD/plasma. I got the 604 as i wasnt bother about running more than one cable...
  6. nathan1977
    nathan1977
    I'm just looking for a upscaling amp which doesn't cost circa £6-700
  7. tigermad
    tigermad
    Jan 2, 2004
    6,359
    Bedfordshire
    +644
    Ignore me
  8. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    ok :D
    on a more serious note...
    far as I know there are no scaling amps below £600....if there are I wouldnt rely on their scaling ability, either that or I wouldnt rely on their amplifying ability...
    scaling isnt something that can be done too cheaply, otherwise its more likely to make things worse than the scaling of your display will....
    if your display is relatively new and not the cheapest panel available, then let that do the scaling, just make sure you have full upconversion to HDMI so you only need one cable.......
    if however you have an older panel or very cheap one, then possibly an amps onboard scaler will be useful......
  9. AVdavid
    AVdavid
    The 674 does not have preamp outputs and only 5.1 audio via HDMI if this is important to you the Sony amps have pre outs and 7.1 audio via HDMI
    Dave
