Anyone know much about SATA RAID....?
Discussion in 'Desktop & Laptop Computers Forum' started by HSC, Jun 8, 2005.
  1. HSC
    HSC
    Nov 23, 2004
    1,979
    63
    Coventry
    +172
    Hi All,
    Anyone know the answer to the following:
    1./ if you had 2 disks making up a raid0 array - is it possible to add more disks to the volume at a later date without breaking the data...?
    2./ do all disks have to be the same type/capacity..?
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    Hi HSC,
    adding new disks later is not a feature that most RAID cards offer, some do but they tend to be at the more expensive end as far as I know. Look for a feature called "online expansion" in the literature of the card.
    The disks in a RAID array don't HAVE to be the same type/capacity but its probably a good idea that they are. If you are doing some sort of mirroring then using two disks of differing sizes would mean that you'd only have the capacity of the smaller one.
  3. Da_Rude_Baboon
    Da_Rude_Baboon
    Jan 12, 2005
    492
    28
    +55
    You should also be aware that putting drives into RAID 0 can actually lower performance over a single drive and even if it does increase the perfomance you probably wont notice it.
    Storage review have a nice article on it here.
