Anyone know anything about these tiny CMOS cameras?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by RSV_Ecosse, Aug 10, 2005.
  1. RSV_Ecosse
    RSV_Ecosse
    Finally got the damn thing up and running, its one of these:-
    http://www.dogcamsport.co.uk/12vcam.htm
    I just went out for a quick run on the bike with it hooked up. It was solidly positioned just under the headlight on the fairing.
    While the image quality was reasonable, the problem I have is that the picture looks like its from some sort of 1980's pop video.....all pink and green hues fading in and out. Its not a vibration issue, the picture itself is very stable. If you hold your hand over the top/above the camera, it seems to improve quite a bit, so I'm guessing that these CMOS type cameras are extremely light sensitive?
    If thats the case, is there anything I can do to solve this? Like maybe, a filter of some sort? Or even something I could "paint" on the lens, to dull its sensitivity down a bit?
    I've got the RCA type leads connected up right, yellow to yellow, white to white and the power lead goes to a 9v battery. There seems to be a bit of background noise, like a low "hum" throughout the footage too. Could this be connected to the image problem?
    Its wired up to a Canon MV750i MiniDV camera via the AV in plug, and AV-DV is set to "on" in the camera menu.
    Any ideas welcomed. Would hate to think I wasted me cash on this thing, although in hindsight, I should really have spent a little bit more and gone for a CCD camera instead of a CMOS.
    HELP!!!! :(
  2. RSV_Ecosse
    RSV_Ecosse
    BTT......
    Anyone?
  3. RSV_Ecosse
    RSV_Ecosse
    It was part of a faulty batch.
    Found this out after I contacted the seller.
    I've sent the faulty one back, he's replacing it with a new one.
