Anyone know anything about facia boards? pls help
Discussion in 'General Chat' started by Ewan154, Sep 17, 2007.
  1. Ewan154
    Ewan154
    Aug 2, 2005
    2,038
    +88
    Does anyone know if Plywood can be used for facia boarding. If it is, is it a special type?
  2. 27neth
    27neth
    Feb 15, 2007
    3,492
    middlesbrough
    +1,294
    It can, i have used it before on a schools fascia boards. It only lasts a couple of years then starts falling apart. It was 18mm exterior ply.
    John.
  3. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    assuming you dont want to stain it then you are better off getting http://www.master-plastics.co.uk/index.html?target=dept_536.html&lang=en-gb this , a far better solution than wood or overcladding with the the thin crap which then allows the old wood to rot behind the new thin upvc :smashin:
  4. Bobdk
    Bobdk
    Feb 2, 2006
    396
    28
    Edinburgh
    +55
    They sell stuff called marine ply which, as the name suggest, goes into making boats and lasts more than a couple of years in the water. It is tough, durable and expensive. Normal ply can last quite well if properly treated with paints/preservers first. Whether it is recommended for the job you have in my I could not say.
    I hope this helps you. As one of the others has already said, there are better alternatives although I wouldn't want to leave wood rotting behind a cover myself.
  5. IronGiant
    IronGiant
    Jun 7, 2003
    66,508
    +46,718
    I have 30 year old plywood facia boards on an extension and although they are in desperate need of repainting (white gloss) the plywood seems fine, not sure what the plywood is though.
    Dave
