Anyone know about Quadral speakers?
Discussion in 'Home Cinema Speakers' started by Tweeter, Dec 31, 2001.
  1. Tweeter
    Tweeter
    I've been offered a number of German made Quadral speakers at what seems a good price, but I can't seem to find out much about them or if there any good. These are the speakers I've been offered: -
    2 x Quadral Caerul QLX205 floor standers
    4 x Quadral Caerul QLX115
    1 x Quadral Caerul QLX base centre speaker
    All brand new and boxed for £850.
    I've tested the two floor standers, they've got lots of base but seem to lack a little detail in the mid range, they were connected to a Denon 3802.
    Are they worth it? has any one else got them or tried them?
  2. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    i would say that 850 for speakers you had better realy like them . if you don't then don't get them
    you can get some very good speaker packages for this sort of money from brand names . eltax for instance do some rather good speakers and you could get a setup for a lot less than that .
    i would go and listen to some other speakers . i would worry aswell if you can only listen to the floor standers . i would say realy the best thing is to listen to the full package to make sure they work together well
  3. tiberious
    tiberious
    www.quadral.com.
    I believe Quadral are well known in Germany and have a good reputation.
