Anyone investigated SACD to DVD-A Conversion?
Discussion in 'Music & Music Streaming Services' started by shaithis, Apr 14, 2005.
  1. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    There seem to be a number of SACDs available I would dearly love to own but the problems with SACD multi-channel standards are causing me not to purchase them...
    Has anyone looked into converting a SACD disk to DD5.1 or DTS? If I could do that I wouldn't mind buying a nice big back-catalogue :smashin:
  2. mjn
    mjn
    May 24, 2001
    22,227
    Herts, England
    +10,059
    DD5.1 and DTS are not DVD-A...so which are you proposing?
  3. Vanderlay
    Vanderlay
    Oct 12, 2004
    47
    I'm not sure what exactly you're suggesting - to do it on a computer and burn DVDs from SACD multichannel tracks?
    Good luck, you need to get a computer drive to read SACD tracks first, which - to my knowledge - is not available at this moment.
  4. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    I wanted to be able to listen to multi channel SACD tracks without buying a new DVD player and adding a ton more cabling to my system...
    Although if its impossible to read SACD on a PC, my idea is a non-starter :(
  5. Mandel
    Mandel
    What problems with SACD multi-channel standards do you mean?
