Anyone In Bristol can help with a pioneer 585 hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by pmarb, Jul 19, 2005.
  1. pmarb
    pmarb
    Oct 29, 2001
    806
    Bristol
    +20
  2. SanPedro
    SanPedro
    Jan 11, 2001
    4,497
    +503
    Hi how did you get sorted?
    Just bought a 585 and I'm looking for multi-region hack.
    Chris
  3. pmarb
    pmarb
    Oct 29, 2001
    806
    Bristol
    +20
    Hi Chris,
    If you have a pronto or something similar there is a code to put in which will then make the 585 multiregion - its on another thread
    I just used multiregionupgrades.com, a very quick service for £20 they send you a remote already preprogrammed , you just put in the batteries push a button to make it multiregion and then send then remote back, works fine :)
