Anyone here using Xbox Live with an Ethernet Modem on BTopenworld?
Discussion in 'Xbox Forums' started by mr_sockochris, Dec 12, 2002.
  1. mr_sockochris
    mr_sockochris
    Dec 19, 2001
    123
    Ware, Hertfordshire, England
    +5
    I bought an ethernet modem for Live but i keep getting a DNS server error when i try to connect. Has anyone here on BTopenworld used Live in the way?
  2. Sinzer
    Sinzer
    May 25, 2002
    5,829
    +1,120
    Which modem is it?
    The likely problem is that the modem needs to be dialled, your X-Box is not capable of doing so (AFAIK). You will need to plug it into a PC to configure or configure a router to dial it.
  3. dope spot
    dope spot
    i keep gettin dns error.how do i fix that?
