Anyone here own a Sony Camcorder & Sony Digital Camera
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Duster, Jul 9, 2003.
  1. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Anyone here own a Sony Camcorder & Sony Digital Camera, and are using a Sony USB driver for both devices?
    If so, did you have any problems installing both drivers, and do both devices work correctly?
    I'm asking because I own a Sony Camcorder (TRV-950) and am running it's USB driver. I'm thinking about buying a Sony digital camera (DSC-P52) which will have it's own USB driver. I'm worried about both USB drivers conflicting with each other.
    Can anyone help me with this?
    Thanks.
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    I have TRV33 and Sue a DC92
    No problems
    BUT I do use Firewire for DV
  3. Duster
    Duster
    Dec 4, 2002
    421
    UK
    So you dont use your TRV33 in USB mode at all then? IE for Photos
  4. kopo
    kopo
    Mar 26, 2003
    16
    3
    Bangor
    i have a dsc-s75 and trv-22
    No problems
    i think they use the same driver for photo
    i haven't try to connect both to the computer at the same time
  5. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Hi Kopo
    Thanks for reply
    So are you only using one driver then, or both?
    I wouldnt want to connect both at the same time, just one or the other.
  6. mij
    mij
    Jan 14, 2002
    3,406
    London
    +605
    I have a Sony TRV 900E and a Sony DSC - P1, both have memorystick, I got a USB reader from Jessops for £22, which is much easier than connecting the Camcorder & Camera.
    mij
  7. dejongj
    dejongj
    I got a Sony Laptop which has got a memory stick reader built in ;-) even easier....
    Only use my TRV-900E directly connected with firewire...
  8. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Memory stick uses USB and the CDs were the same
  9. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Thanks for the info guys:cool:
  10. Duncan Craig
    Duncan Craig
    Jun 1, 2003
    258
    The Grim North
    +17
    FAO MartinImber or kopo
    I'm after a Sony TRV22 as a second camera.
    Can you tell me how you manually control the focus, does the lens rotate by hand, or do you focus with a menu?
    I have a Sony VX2000 and wondered if the TRV22 takes batteries from other Sony kit.
    Could you measure the base of battery for me?
    Cheers All,
    Duncan.
  11. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Don't know that much about the 22 except it is not as good at widescreen.
    However this range the manual focus is done on the touch screen
    Batteries are
    NP-FM30/50/70/QM71/FM91/QM91
  12. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Hi Guys,
    Just got this from Sony Support
    "We can confirm that the DSC-P52 can indeed use the same drivers as the
    DCR-TRV950E and therefore providing you do not connect both products at the
    same time you should not experience any difficulties. We can also confirm
    that the DSC-P52 is compatible with both USB 1.1 and Windows ME."
    So my problem is solved.
    My thanks to all those that help
    :smashin:
    Regards
    Duster.
